Is your computer not loading properly? Consider using this guide to replace the RAM in your device.
Begin with the bottom of the laptop facing up.
With a screwdriver, unscrew the four phillips #0 7.5mm screw around the bottom panel.
Lift the panel at the top and pull towards you to remove it from the laptop.
The memory should be to the right, after you have removed the bottom panel.
Towards the bottom of the memory card, push outwards on the two small silver levers to release the memory card.
Pull the memory card out towards you to remove it.
