Acer Aspire 7736Z-4809 RAM Replacement
  1. Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  2. Acer Aspire 7736Z-4809 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back panel of the laptop.
  3. Acer Aspire 7736Z-4809 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  4. Acer Aspire 7736Z-4809 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the tabs on the RAM by bending the tabs away from the RAM.
    • The RAM will rise upwards at an angle.
  5. Acer Aspire 7736Z-4809 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 7736Z-4809 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the RAM out of the slot.
    • If you are replacing both sticks of RAM, repeat the previous step for removing the RAM.
Pnithan Jantarakolica
crwdns2935283:009/22/16crwdne2935283:0
1.153 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-4, Oliver Fall 2016 crwdns2935289:0UC Davis, Team 2-4, Oliver Fall 2016crwdne2935289:0
UCD-OLIVER-F16S2G4
“supports the DDR2 667MHz memory,240-pin soDIMM RAM “
It’s a laptop and what you are holding is a 200-pin soDIMM RAM module.
BaronDRS - crwdns2934203:0crwdne2934203:0
Not only is it 200-pin soDIMM module instead of a 240-pin soDIMM module, it's a pc2-6400 (800MHz) and not a pc2-5300 (667MHz).
1videopirate - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 706
