Acer Aspire 7736Z-4809 CPU Fan Replacement
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the modified or new cooling fan.
Pnithan Jantarakolica
crwdns2935283:009/22/16crwdne2935283:0
1,153 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-4, Oliver Fall 2016 crwdns2935289:0UC Davis, Team 2-4, Oliver Fall 2016crwdne2935289:0
UCD-OLIVER-F16S2G4
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 956
