This guide will show you how to remove the keyboard of your device in order to replace it. You may need to do this if it has become non-responsive or faulty, or if keys are missing.
Make sure the device is unplugged and completely powered down.
Turn the device over.
The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
Slide the switch away from the battery.
The battery release switch is just to the inside of the battery and slides parallel to it.
Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
Pull the battery up and out. Use a plastic opening tool if necessary.
Using the Phillips #1 screwdriver, remove the nine 7mm screws holding the top panel.
Flip device right side up and open it.
Lift the top panel up, rotating forward onto the keyboard.
Lift the black latch on each connection securing the cables.
Pull the cable free.
Lift the keyboard up by the center of the back. You may need a plastic tool such as the black plastic spudger to get under the edge.
Lift up, pulling the edges from under the top cover, and lay down on the front of the device.
Lift the black clasp holding the cable.
Remove the keyboard.
