Just as simple as it gets! to work on a laptop, well there you have the Acer Aspire 5742G and the easiest job to change memory sticks!
crwdns2936621:0crwdne2936621:0
click here for video
Make sure your computer is off and remove the battery with the security tabs shown in the picture
Remove these philips screws, only two :)
Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
Easily work your way around.
Please remove both tabs with the memory stick at the same time
Now put the new memory stick in!
When it is in, then gently push it downwards to lock it in place!
