Acer Aspire 5742 LCD Panel Replacement
  1. Acer Aspire 5742 LCD Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 5742 LCD Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 5742 LCD Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 LCD Panel Replacement, Screen bezel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop lid as far as it will go. Using a small craft knife or similar, remove the two black adhesive screw covers on either side of the screen at the bottom, by inserting the tip of the blade under the edge of the cover.
    • Remove the 2 screws now revealed.
  3. Acer Aspire 5742 LCD Panel Replacement, Removing the screen bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the bezel around the screen by using a jimmy or similar tool to release the clips holding it in place. Work around both sides and the top. Finally, turn the laptop on its side in order to work along the bottom. You should now be able to lift off the bezel.
  4. Acer Aspire 5742 LCD Panel Replacement, Removing the LCD panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 screws from the bottom of the LCD panel.
    • At the top of the LCD panel, remove the 2 screws furthest from the corners. Support the panel as you remove these screws.
    • Very gently angle the LCD panel forwards and lay it face down.
  5. Acer Aspire 5742 LCD Panel Replacement, Disconnecting the video cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the transparent adhesive film covering the video connector on the back of the LCD panel, and disconnect the connector.
    • You can now completely remove the LCD panel.
Philip Le Riche
crwdns2935283:002/18/14crwdne2935283:0
31.060 crwdns2915208:0crwdne2915208:0
crwdns2935297:047crwdne2935297:0
Restart Project crwdns2935289:0Restart Projectcrwdne2935289:0
Local Repair Groups
crwdns2931471:022crwdne2931471:0
crwdns2935297:0359crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,550
