Removal of the CMOS battery is a very quick and simple procedure. The CMOS battery will lose its charge over time and cannot be recharged, therefore you will need to replace it from time to time (very infrequently). No special caution is needed to follow this guide other than to be gentle with the laptop and do not to touch any electrical components not mentioned in the guide.
Move the battery catch to the "unlocked" position.
Pull back the second spring-loaded battery catch until the battery pops up.
Remove the battery.
Turn the notebook around to face you.
There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
Use a spudger to release the panel from the plastic retaining clips keeping it in place.
Remove the panel and set it aside.
The CMOS battery is the silver coin-like object in the center.
Press the tip of the spudger underneath the CMOS battery with very slight force.
Press down on the opposite side of the battery while prying the battery upward with the spudger.
After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
Thanks! Too much info in all of the other tutorials I read. Battery replaced, working perfectly now.
crwdns2935229:08crwdne2935229:0
the best tueture
