The WiFi card allows for the user to have internet access. If the WiFi card is broken, the Acer Aspire 5740-6378 will still work, but without the capabilities of using the internet. It is highly suggested that you remove the battery before performing this replacement.
Slide the locking switch into the unlocked position to ready the battery for removal.
Slide the release latch until the battery pops out.
Remove the battery now that it's been unsecured.
Flip over the device so the back is facing upward.
Remove the five 8.7mm Phillips #0 screws securing the back panel.
Use the black spudger to pry open the back panel.
The WiFi card should be directly above the hard drive. Detach the two coaxial connectors attached to the WiFi card by pulling on them.
Remove the two 3mm Phillips #0 screws securing the WiFi card.
