Acer Aspire 5734z-4836 Screen Replacement
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5734z-4836 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
Susan Cao
crwdns2935283:009/12/16crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-3, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 2-3, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S2G3
crwdns2942667:0crwdne2942667:0 1,015
