The keyboard replacement is a simple replacement guide, but to remove the panel some force may be necessary.
Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
Slide the right latch down to unlock the battery.
Slide and hold the left latch below the battery.
While holding this latch in place, pry the battery up from its bottom edge.
Lift the old battery out of its compartment.
Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
Pull the keyboard off gently so not to damage the keyboard ribbon cable.
Using a spudger or your finger, unlock the ZIF connector holding the keyboard ribbon in place by lifting the black locking lever.
Pull the blue keyboard ribbon cable from the ZIF connector.
