This guide is on how to replace the random access memory in an Acer Aspire from the 5552 series.
Remove the following Phillips 0 screws.
Using an opening device; insert it into the notch, and slide the device along all sides to pop the plate out.
Gently pull apart on these metal tabs and the RAM will pop up. This can then be safely removed by hand.
Well laid... Easy does it... Looking forward to learn more from you by been your student☺️
