Replacing the disc drive is a fairly simple process that can be completed in around 5 minutes. Make sure the device is unplugged and powered off before you begin.
Unscrew the two .8 centimeter screws on the bottom plate with the PH #0 screwdriver.
Using your fingers, or the blue plastic spudger tool if needed, remove the plate.
Then proceed to unscrew the .4 centimeter Phillips screw on the left side.
You can now pull the disk drive out by hand.
If needed, the small plate can be removed by unscrewing the two .4 centimeter Phillips screws.
