This guide will walk you through how to replace a broken or damaged battery on your Acer Aspire 5517-1127 laptop. If your device does not power on, shuts off, or will not charge, this guide may be able to assist you.
Orient the laptop so that it is upside down facing away from you. The battery is at the bottom.
The smaller switch is on the left. Move it to the unlock position.
Once unlocked, move the larger switch on the right to the left to release the battery.
When the switch is moved to the left, the battery will pop up and become removable.
