Acer Aspire 5100 LCD Monitor Replacement
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the monitor to detach it.
crwdns2935229:08crwdne2935229:0
Brad Rollinson
crwdns2935283:009/29/10crwdne2935283:0
1,113 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-39, Forte Fall 2010 crwdns2935289:0Cal Poly, Team 14-39, Forte Fall 2010crwdne2935289:0
CPSU-FORTE-F10S14G39
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 15,740
