Acer Aspire 5 A515-56-347N Battery Replacement
  1. Acer Aspire 5 A515-56-347N Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Acer Aspire 5 A515-56-347N Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Acer Aspire 5 A515-56-347N Battery Replacement, Disconnecting the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement, Disconnecting the Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement, Disconnecting the Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Acer Aspire 5 A515-56-347N Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
  5. Acer Aspire 5 A515-56-347N Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 5 A515-56-347N Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.7 mm Phillips #0 screws from each side of the battery.
  6. Acer Aspire 5 A515-56-347N Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is now fully loosened. Gently lift it out of the laptop and set it aside.
Ethan Griffin
crwdns2935283:002/21/24crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
University of Kentucky, Team 1-1, Martin Spring 2024 crwdns2935289:0University of Kentucky, Team 1-1, Martin Spring 2024crwdne2935289:0
UKY-MARTIN-S24S1G1
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,096
