Use this guide to replace the lower case on a Acer Aspire 3 A315-24PT-R288.
Use a Phillips screwdriver to remove the eleven 2 mm screws that secure the lower case.
Insert an opening pick in the seam between the chassis and the lower case.
Slide the opening pick around the entire perimeter, prying every couple of centimeters, to release all of the retaining clips that secure the lower case.
Remove the lower case.
