In this guide, Acer Aspire 3 owners will learn how to replace their SSDs. Some common reasons would be to increase their laptop speeds, replace a faulty drive or to replace one you've had over five years. Some signs to look for a defective drive are files not being read or written, file system needing to be constantly repaired or frequent crashes when booting your laptop.
Power off the machine and unplug it from the wall charger.
Close the laptop and flip it over.
Remove the eleven 6.5 mm Phillips screws from the lower case.
Insert an opening pick between the lower case and chassis.
Pry around the entire perimeter until the lower case releases.
Remove the lower case.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Unscrew the one 2.2 mm Phillips head screw that secures the SSD.
Gently grasp the drive and pull it directly out of its socket.
what is the maximum storage it can support? I wanna upgrade to a 2tb ssd
is there one ssd for the storage and one for the windows boot? I just dont want to have to do a new windows install
