This guide shows you how to completely remove and replace your Acer Aspire 3 motherboard. Some tell-tale signs that your motherboard needs replacing are increased Windows errors, "blue screens of death", or the laptop failing to boot before shutting down.
Power off the machine and unplug it from the wall charger.
Close the laptop and flip it over.
Remove the eleven 6.5 mm Phillips screws from the lower case.
Insert an opening pick between the lower case and chassis.
Pry around the entire perimeter until the lower case releases.
Remove the lower case.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Grip the white battery connector and pull it directly out of its socket.
Unscrew the four 4.5 mm Phillips head screws that secure the battery.
Lift the battery up and out of the chassis.
Unscrew the one 2.2 mm Phillips head screw that secures the SSD.
Gently grasp the drive and pull it directly out of its socket.
Find the speakers at the bottom left and right corners of the laptop.
Disconnect the white ribbon cable from the motherboard, near the Network Interface Card, by lifting up the black locking flap then gently pulling it out of its socket.
Unscrew the three 4.5 mm screws that secure the heatsink.
Unscrew the two 5.6 mm Phillips screws that secure the fan.
Disconnect the fan cable connection.
Remove the fan.
Remove the one 4.5 mm Phillips screw holding the motherboard to the laptop frame.
Gently lift the motherboard up and out of the chassis.
