Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement
  1. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the black and white antenna cables plugged into the network card on the motherboard.
    • Unscrew the four 5.5 mm Phillips screws holding the hinges of the monitor to the laptop frame.
  6. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the hinges are unscrewed the display assembly will easily come off.
To reassemble you will just follow these steps in reverse order.
AlexHarpring
crwdns2935283:009/07/23crwdne2935283:0
319 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-1, Pee Fall 2023 crwdns2935289:0Gateway, Team 1-1, Pee Fall 2023crwdne2935289:0
GCC-PEE-F23S1G1
crwdns2942667:0crwdne2942667:0 897
