Acer Aspire 1410 Disassembly
  1. Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With laptop closed, turn screenside down and remove the battery.
    • Unscrew covers and remove HDD.
    • Unscrew cover and remove RAM.
    • Unscrew and remove cover for fan.
  2. Acer Aspire 1410 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn laptop so that hinges are closest to you and remove screw from rear of each hinge.
    • Remove screws securing bottom case to logic board. (It won't come off just yet though)
  3. Acer Aspire 1410 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn laptop over and open the screen fully. Take care as the screen is still connected to the logic board via black cable on right hinge.
    • Use a spudger to release the silver and black plastic cover that forms the hinge covers. Start at one side nearest a hinge and work along the rear of the case, there are 5 tabs to release along the keyboard edge.
    • Disconnect LCD cable by lifting straight upwards using the black plastic tabs on the top of the LCD connector. You may need to use a spudger to loosen the connection along the uppermost edge-not along the logicboard.
    • Remove 2 screws from left and right hinges.
    • Remove 2 screws securing topcase to rear of battery tray.
  4. Acer Aspire 1410 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 screws securing power board to logicboard.
    • Lift LCD screen from bottom case.
    ES1-411-c6j0 párpado la pantalla y no prende que ago en este caso por favor
    francisco narvaez martinez - crwdns2934203:0crwdne2934203:0
  5. Acer Aspire 1410 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 screws securing the keyboard to case.
    • Use a spudger to release tabs on all 4 sides of the keyboard. Do not pull keyboard up too far as the trackpad and keyboard flex cables are still attached to the logicboard.
    • Place ducks in sink, make sure to disinfect sink afterwards.
    Where do I find these ducks at? My computer apparently didn't come with them. I must have the wrong model.
    Derek Phillips - crwdns2934203:0crwdne2934203:0
  6. Acer Aspire 1410 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not pull keyboard upwards as it is still attached to logicboard.
    • Flip keyboard over to cover trackpad. Disconnect keyboard.
  7. Acer Aspire 1410 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect trackpad.
    • Use a spudger to ease topcase free of bottom case. Slide topcase toward trackpad and then lift up. Resistance can be felt from magnets on topcase.
    • Your laptop should now look like this; middle photo is the remaining logicboard and bottom case, the last photo is the topcase cover.
  8. Acer Aspire 1410 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove logicboard screws.
    • Remove the 2 screws securing the modem.
    • Disconnect wire from the modem to the logicboard.
    • Disconnect the speaker wire form the logicboard.
  9. Acer Aspire 1410 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use hex no.5 tool to unscrew 2 bolts from port next ac-in jack.
  10. Acer Aspire 1410 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire 1410 Disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide DVD drive from logicboard frame.
    • Slide logicboard toward trackpad and then lift out of logicboard frame. The logicboard has a pin connection to the battery tray preventing direct lifting of the logicboard.
    • Last 2 photo's show top of logicboard and underside of logicboard.
To reassemble your device, follow these instructions in reverse order. Remember to place logicboard in ac power connection end in first
crwdns2935229:022crwdne2935229:0
pollytintop
crwdns2935283:006/09/10crwdne2935283:0
77,356 crwdns2915208:0crwdne2915208:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01,686crwdne2935297:0
Great start, but this is not my 1410 and there is no selection for other models. The one I have is much smaller. Mine is model 1410-2817.
William Nelson - crwdns2934203:0crwdne2934203:0
Great effort but my model does not mach, much smaller, 1410-2817.
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 17,701
