Acer AL1714 LCD Replacement
    1. Acer AL1714 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL1714 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the monitor facedown.
      • Unscrew the 5 screws holding the back cover on.
      • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
    2. Acer AL1714 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Take the edge tool or a metal ruler and insert it into the bezel.
      • Apply pressure and push down.
      • Do the same to the right side.
      • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
      • (This will require some force, you will hear a loud popping/snapping noises)
    3. Acer AL1714 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the Power Button Circuit Board Flat Flex Cable from the Power Supply board under the metal cover.
      • Pull the cord back and out of the way.
      • (It may be stuck down with adhesive)
    4. Acer AL1714 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the cord anchors for the VGA port.
      • (Use needle nose pliers if they're too tight for removal by hand)
    5. Acer AL1714 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the monitor around.
      • Unscrew the 1 screw holding the Flat Power Cable cover in place.
      • Lift up and remove the Flat Power Cable cover.
      • (Careful: it may be sharp)
    6. Acer AL1714 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 5 screws holding the metal cage on.
    7. Acer AL1714 LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up on the back of metal cage, slightly.
      • Pull the cage toward self.
      • (Must be careful to free cover of the VGA port and power supply input)
    8. Acer AL1714 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift up on the Flat Flex Cable holder tabs to release the cords.
      • Lift up on the Flat Flex Cables and bend them out of the working area.
    9. Acer AL1714 LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug the 4 backlight wires from their ports on the Power Supply board.
      • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling and pulling the wires out of place)
    10. Acer AL1714 LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 5 screws holding the Power Supply and Video Display boards.
    11. Acer AL1714 LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift and remove the joined Power Supply and Video Display boards.
    12. Acer AL1714 LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully detach the Power Supply and Video Display boards at the connector joint.
      • (This step is not necessary to replace the LCD Module. This step is only a safety precaution so as not to bend or break the Power Supply connector joint)
    13. Acer AL1714 LCD Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Flat Flex Cable from the Power Button Circuit board.
    14. Acer AL1714 LCD Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer AL1714 LCD Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Grasp, lift, and remove the LCD Module from the front panel.
    15. Acer AL1714 LCD Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The final product with the LCD Module removed.
Christopher Kelly
crwdns2935283:009/25/14crwdne2935283:0
590 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 1-3, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S1G3
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 4,119
