Accessing Samsung ML2510 Circuit Board
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Samsung ML2510 Circuit Board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
bbaustin
crwdns2935283:010/12/11crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-18, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-18, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G18
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,926
