Accessing Logicboard
crwdns2869540:0crwdne2869540:0: 2,3K
3
24
106
2.309
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:07crwdne2931287:0
In this guide you will learn how to remove the SD card circuit board to access the logic board. To access the logic board, you will need to unsolder two leads. For soldering instructions, please refer to steps 1 through 6 of this soldering guide.
    1. Accessing Logicboard, Front and Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard, Front and Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    2. Accessing Logicboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    3. Accessing Logicboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the back of casing away from the front.
    4. Accessing Logicboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Logicboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Logicboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    5. Accessing Logicboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    1. Accessing Logicboard, Logicboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard, Logicboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
    2. Accessing Logicboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
    3. Accessing Logicboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the cover plate off for the two power cord jacks.
    4. Accessing Logicboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Logicboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Logicboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    5. Accessing Logicboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the orange tape on top of the SD cardholder.
    6. Accessing Logicboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the battery cover.
    7. Accessing Logicboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the indicated plastic piece off.
    8. Accessing Logicboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing Logicboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove screws indicated:
      • Two black 4.80mm Phillips #00 screws
    9. Accessing Logicboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unsolder points indicated.
      • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
    10. Accessing Logicboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing Logicboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing Logicboard: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully lift up SD cardholder to reveal logicboard.
Nicole Wong
crwdns2935283:001/30/11crwdne2935283:0
371 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-29, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-29, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G29
crwdns2936753:030crwdne2936753:0 106
crwdns2959996:0crwdne2959996:0 2,309
