Accessing LCD Screen
    1. Accessing LCD Screen, Front and Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing LCD Screen, Front and Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    2. Accessing LCD Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    3. Accessing LCD Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing LCD Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the back of casing away from the front.
    4. Accessing LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    5. Accessing LCD Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing LCD Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    1. Accessing LCD Screen, LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing LCD Screen, LCD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
    2. Accessing LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing LCD Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
    3. Accessing LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the cover plate off for the two power cord jacks.
    4. Accessing LCD Screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    5. Accessing LCD Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the orange tape on top of the SD cardholder.
    6. Accessing LCD Screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the battery cover and lift plastic piece off.
    7. Accessing LCD Screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove tape on left side of camera.
    8. Accessing LCD Screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
    9. Accessing LCD Screen: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove top left LCD bracket.
      • This is a small piece, be careful not to lose it.
    10. Accessing LCD Screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Accessing LCD Screen: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push down bottom left LCD bracket to release the LCD from grip.
    11. Accessing LCD Screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift up LCD screen.
    12. Accessing LCD Screen: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Accessing LCD Screen: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slowly pull LCD screen to the left to remove it from the other grips.
      • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
Bassem Tossoun
crwdns2935283:001/21/11crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-29, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-29, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G29
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 1,604
