crwdns2959928:0crwdne2959928:0 ↓In this guide, you will be able to access and remove the LCD screen from the camera's frame.
Spudger4.9
Remove the following screws:
Two silver 3.15mm Phillips #00 screws on the right side of the camera
Two silver 2.08mm Phillips #00 screws on the left side of the camera
Remove the two indicated screws on the bottom of the camera:
The screw circled in red is a longer silver 3.15mm Phillips #00 screw
The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
Carefully pull the back of casing away from the front.
Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
On the front of the camera, in battery case, remove screws indicated:
Two black 2.05mm Phillips #00 screws
Flip the camera over to the backside and remove screws indicated:
The screw circled in red is a longer black 3.00mm Phillips #00 screw
The screw circled in red is a shorter black 2.00mm Phillips #00 screw
Pull the cover plate off for the two power cord jacks.
Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
Remove the orange tape on top of the SD cardholder.
Open the battery cover and lift plastic piece off.
Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
Push down bottom left LCD bracket to release the LCD from grip.
Slowly pull LCD screen to the left to remove it from the other grips.
