AYL SoundFit Motherboard Replacement
  1. AYL SoundFit Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AYL SoundFit Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AYL SoundFit Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AYL SoundFit Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
    Where do I get a new Motherboard to replace the one I have just taken out?
    Mikie Groscurth - crwdns2934203:0crwdne2934203:0
    Where do I get a new Motherboard to replace theone I have just taken out?
john
crwdns2935283:003/10/16crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Spring 2016 crwdns2935289:0IUPUI, Team 3-3, Harley Spring 2016crwdne2935289:0
IUPUI-HARLEY-S16S3G3
Where do u get a new motherboard at?
calvinsmith522 - crwdns2934203:0crwdne2934203:0
Anybody know where to get a motherboard?
David Whitman - crwdns2934203:0crwdne2934203:0
Where do I get a motherboard?
crwdns2942667:0crwdne2942667:0 1,627
