AVM Fritz Fon C5 front cover / keypad Replacement
  1. AVM Fritz Fon C5 front cover / keypad Replacement, Back panel and battery removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AVM Fritz Fon C5 front cover / keypad Replacement, Back panel and battery removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the back panel using your fingernail/ guitar pick or a spudger.
    • Slide the pick all around the housing until the back panel comes off.
    • Once it's off simply remove the battery from the housing.
  2. AVM Fritz Fon C5 front cover / keypad Replacement, Loosen Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AVM Fritz Fon C5 front cover / keypad Replacement, Loosen Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AVM Fritz Fon C5 front cover / keypad Replacement, Loosen Housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the 8 T5 screws, and set them aside.
    • The upper shell / front of the housing consists of filigree bars around the keypad, so special care is required here. In my case, some of these were already broken.
    • Move the opening pick / spudger around the case, lifting off the tabs (orange) with a flat screwdriver. This is done through the corresponding openings in the middle part of the housing (green).
  3. AVM Fritz Fon C5 front cover / keypad Replacement, PCB removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AVM Fritz Fon C5 front cover / keypad Replacement, PCB removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The circuit board can then be easily removed together with the keypad.
    • Replace the parts to be repaired and screw them back together.
  4. AVM Fritz Fon C5 front cover / keypad Replacement, Speaker and Display Window: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AVM Fritz Fon C5 front cover / keypad Replacement, Speaker and Display Window: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loudspeaker (yellow) and screen protector (green) are glued on and can be easily lifted out with a flat screwdriver.
    • A transparent piece of plastic (light blue), which was probably used to align the loudspeaker, was no longer needed, nor was I able to take over the piece of fabric (red) in front of the loudspeaker.
    • The keypad got hooked in a few places, so I had to rework the associated openings with a file.
  5. AVM Fritz Fon C5 front cover / keypad Replacement, Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put everything back together in reverse order - make sure that the buttons do not get stuck.
Reverse the steps to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Peter Scholl
crwdns2935283:006/26/21crwdne2935283:0
1,818 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
Yea please cam you help me
James - crwdns2934203:0crwdne2934203:0
I can’t say without knowing your question/problem.
Peter Scholl -
Ich finde auf eBay aktuelle keine 3D gedruckten C5 Oberschalen. Können Sie mir einen Tipp geben, wo man so etwas erhält?
H. Zapf - crwdns2934203:0crwdne2934203:0
Hallo - da kann ich leider nichts zu sagen, da ich meine Oberschale selbst gedruckt habe. Ich habe auch keine Erfahrung wie es ist, wenn man einen solchen Druck in Auftrag gibt - falls Sie da Erfahrung sammeln, fände ich eine kurze Info auch interessant. Viel Erfolg!
Peter Scholl - crwdns2934203:0crwdne2934203:0
Hallöle, kannst du die 3D zur Verfügung stellen.
Grüße
M O -
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 292
crwdns2942667:0crwdne2942667:0 24,464
