ATT EL52300 LCD Screen on Handset Replacement
  1. ATT EL52300 LCD Screen on Handset Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
    • Pop off the indicated clip using a pointed tweezer.
    • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
  7. ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
    • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
  8. ATT EL52300 LCD Screen on Handset Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The display has a line of soldered connections to the motherboard. These all need to be undone with a soldering tool, so the screen can be removed.
    • Please refer to the How To Solder and Desolder Connections for soldering help.
Katty
crwdns2935283:008/27/15crwdne2935283:0
340 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-1, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 603
