This guide is used to help setup your AT-LP60X after receiving back from a repair.
Place your turntable on a clear, flat surface.
Ensure there is no power connected to the turntable at this time.
Obtain the silver metal platter.
Verify that the belt is installed around the inner ring of the platter.
Place the platter on the center spindle.
Rotate the platter to show the gold pulley of the motor.
Stretch the belt from the platter over the gold pulley of the motor.
Place the slipmat on top of the platter and press the STOP button.
With your right hand, hold the tone arm in place.
With your left hand, rotate the platter clockwise about 10 times.
Reconnect the power supply.
Connect the 3.5mm to RCA to your speakers.
For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
Unsecure the twist tie from the built-in hook (if present).
Ensure the tone arm lift button is in the outward position.
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
