AT-LP60X Setup Guide
  1. AT-LP60X Setup Guide, Place Turntable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AT-LP60X Setup Guide, Place Turntable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your turntable on a clear, flat surface.
    • Ensure there is no power connected to the turntable at this time.
  2. AT-LP60X Setup Guide, Locate and Install Platter/Belt: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Obtain the silver metal platter.
    • Verify that the belt is installed around the inner ring of the platter.
  3. AT-LP60X Setup Guide, Install Platter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AT-LP60X Setup Guide, Install Platter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the platter on the center spindle.
    • Rotate the platter to show the gold pulley of the motor.
    • Stretch the belt from the platter over the gold pulley of the motor.
  4. AT-LP60X Setup Guide, Preform Mechanical Reset: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AT-LP60X Setup Guide, Preform Mechanical Reset: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the slipmat on top of the platter and press the STOP button.
    • With your right hand, hold the tone arm in place.
    • [OPTIONAL] use the included hook and twist tie for this step.
    • With your left hand, rotate the platter clockwise about 10 times.
    • You should hear a series of clicks and pops.
  5. AT-LP60X Setup Guide, Reconnect Turntable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the power supply.
    • Connect the 3.5mm to RCA to your speakers.
    • For powered speakers the output switch should be in "LINE", if connecting to an amp/phono input the output should be in "PHONO"
    • The output switch position does not matter if you are connecting to a Bluetooth speaker.
  6. AT-LP60X Setup Guide, Prepare Tonearm: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AT-LP60X Setup Guide, Prepare Tonearm: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AT-LP60X Setup Guide, Prepare Tonearm: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the clear plastic cover from the stylus (if present) by sliding the COVER ONLY directly towards the front of the turntable.
    • Unsecure the twist tie from the built-in hook (if present).
    • Ensure the tone arm lift button is in the outward position.
    • The setup is now complete and you are ready to try a record!
If you have any trouble setting up your turntable and/or a new problem arises, feel free to contact a technician at (330)686-2600 ext.5004 or service@atus.com
Anthony @ ATUS
crwdns2935283:002/28/19crwdne2935283:0
1.195 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 340
