AT-LP60X Cam Gear Assembly Replacement
  1. AT-LP60X Cam Gear Assembly Replacement, Remove Power From The Turntable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power source located on the back of the turntable.
  2. AT-LP60X Cam Gear Assembly Replacement, Press The Stop Button: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the stop button located at the front of the turntable one time.
    • During this step, remove your record (if one is on the turntable) and remove the black felt mat.
  3. AT-LP60X Cam Gear Assembly Replacement, Perform Mechanical Reset: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your right hand, hold the tone arm in the rest so that it does not move.
    • With your left hand, slowly rotate the platter clockwise until you hear a series of clicks.
    • After hearing the series of clicks, the cam gear assembly should not rotate while you continue to rotate the platter - if the cam gear is still rotating, press the stop button again and repeat step 3.
    • Cam gear assembly - white gear visible through holes of the platter.
    • Allowing the tone arm to move freely during this process can result in the stylus being broken.
  4. AT-LP60X Cam Gear Assembly Replacement, Detach Belt & Remove Platter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AT-LP60X Cam Gear Assembly Replacement, Detach Belt & Remove Platter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the belt up and off of the gold pulley.
    • Remove the platter by grabbing the platter from the two circles, and pull straight up.
  5. AT-LP60X Cam Gear Assembly Replacement, Remove Screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw in the center of the cam gear assembly.
    • Keep screw for Step 9.
  6. AT-LP60X Cam Gear Assembly Replacement, Remove Cam Gear Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screw is removed, pull the cam gear directly up to remove it.
  7. AT-LP60X Cam Gear Assembly Replacement, Adjust Shaft Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the metal shaft against the metal bar.
    • Ensure brass bushing is lying flat in between the grooves.
    • Position the white plastic part such that it is touching the hole closest to the center post.
  8. AT-LP60X Cam Gear Assembly Replacement, Position New Cam Gear Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AT-LP60X Cam Gear Assembly Replacement, Position New Cam Gear Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new cam gear assembly on the center post, it will fall into place once the rest of this step is complete - DO NOT force the cam gear assembly down.
    • When the cam gear is placed, the open area of the cam gear should be facing the inner spindle as shown.
    • Locate the metal hook at the end of the spring, and gently slide it away from the cam gear until the cam gear drops into position.
  9. AT-LP60X Cam Gear Assembly Replacement, Mount New Cam Gear Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Secure the cam gear assembly with the screw set aside from Step 5.
  10. AT-LP60X Cam Gear Assembly Replacement, Mount Platter And Belt: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AT-LP60X Cam Gear Assembly Replacement, Mount Platter And Belt: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AT-LP60X Cam Gear Assembly Replacement, Mount Platter And Belt: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the platter upside-down and ensure the belt is stretched around the inner ring.
    • Mount the platter back onto the center spindle.
    • Stretch the belt around the gold pulley.
    • If the belt is connected to anything except the silver platter and the gold pulley this will cause the platter to spin inconsistently.
  11. AT-LP60X Cam Gear Assembly Replacement, Reconnect Power: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the power source to the turntable.
  12. AT-LP60X Cam Gear Assembly Replacement, Place Slipmat And Record: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the slipmat back onto the platter, and try a record.
    • If the automatic start/stop function still does not work properly, the turntable would likely need to be sent in for repair. Please follow the instructions found in the warranty/repair section at the bottom of www.audio-technica.com
    • If you are sending the turntable in for repair - DO NOT SHIP ANY ACCESSORIES (DUST COVER, HINGES, BELT, PLATTER, SLIPMAT, OR CABLES). IMPROPER SHIPPING CAN CAUSE NON-REPAIRABLE DAMAGE TO THE TURNTABLE.
Anthony @ ATUS
crwdns2935283:002/28/19crwdne2935283:0
1,195 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 706
