ASUS ZenWatch Motherboard Replacement
  1. ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenWatch Motherboard Replacement, Watch Strap Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
    what is connector called so joint circuit to battery . if when i purchase in market i do not know it is name please tell me name thanks.
    SKY BIRD - crwdns2934203:0crwdne2934203:0
  4. ASUS ZenWatch Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the battery up with the plastic pry tools
  5. ASUS ZenWatch Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the metal tweezers gently remove the fabric covering the connection on bottom right
    • Using the heavy duty plastic spudger pry up on the connection ribbon.
    • There are two connection ports on the single ribbon. Do not use too much force as you may tear ribbon!
  6. ASUS ZenWatch Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Heavy-Duty Spudger
    • The protective plate is now ready to be safely removed.
    • With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
    • There are tiny notches on plate making it simple to pull up on each side.
    • A small strip of adhesive is on back of plate as well.
    • Remove loosened plate and set aside.
  7. ASUS ZenWatch Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the 000 Philips screwdriver remove the screw and plastic retainer clips
  8. ASUS ZenWatch Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With heavy duty spudger lift up on final connection ribbon located on left corner.
  9. ASUS ZenWatch Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenWatch Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
Wayne McClure
crwdns2935283:002/10/16crwdne2935283:0
961 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-3, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G3
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
Davy Jones - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,677
