ASUS ZenWatch Charging Cradle Circuit board Replacement
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Charging Cradle Circuit board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenWatch Charging Cradle Circuit board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Wayne McClure
crwdns2935283:002/10/16crwdne2935283:0
961 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-3, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G3
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,932
