ASUS ZenPad S 8.0 Daughter Board Replacement
  1. ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
    Be very careful when prying apart the back case. I was very cautious but still managed to slightly warp the silver bezel at one location, so after reassembly I have one small section of this bezel that won’t snap completely flush with the back case. That said, opening this tablet is surprisingly easy.
    Christian Dummer - crwdns2934203:0crwdne2934203:0
  2. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
    I removed both ribbon ends on the ASUS-labelled ends of the cable. FWIW, one of my connector lock tabs is white & the other is black.
    license - crwdns2934203:0crwdne2934203:0
    In my case (a Z580CA instead of the Z580C pictured) one of the lock tabs was white and the other black, as the previous comment noted, but also the printing on the ribbon cables is slightly different (i.e. the white ribbon cable had “ASUS” printed on its left end, instead of what’s pictured above). What seems more consistent among models is the ID printed on either end of each ribbon cable:
    Top (white) cable: “SB” or “FPC_SB” ⟧≣≣≣≣⟦ “MB” or “FPC_MB”
    Bottom (orange) cable: “LCM” ⟧≣≣≣≣⟦ “MB”
    So, all in all, I agree with the previous comment — it’s enough if you remove the connectors on the “MB” end only.
    Bottom line cable holder colors were inverted. I destroyed my tablet because I followed “pry open white part”. :-(
    Mihail Turusov - crwdns2934203:0crwdne2934203:0
  3. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
    The tray only provides a mounting location for the battery which is securely stuck to the tray with foam tape. Pry them gently apart. I reinstalled my tray & screws, then reconnected the power cable and finally placed the battery into the tray. The clone battery is physically smaller than the original and the power cable isn’t in quite the same place but it does fit.
    In my case I did remove the metal tray as I found it easier to pull the battery away once I had the tray in my hand. But if you know approximately where to insert a plastic tool to help separate the tape, I fully agree that removing the metal tray is completely unnecessary. FWIW, in my case I had two strips of double-sided tape, running vertically (considering the orientation of the picture above), one of them approximately at the level of the screw in the 11-o’clock position, the other approximately at the level of the 5-o’clock screw.
    Also, my tablet (Z580CA) had only eight screws (weird — the one at the 3-o’clock position was missing) and I found them to more closely match a 2.0mm screwdriver head.
    The battery part number shown in one of the pictures and what is in my tablet is C11Pn9H. I ordered a Cameron Sino C11P1304 from Amazon that states it’s compatible with a C11Pn9H. It really is not. It’s smaller and the power conector is 1/4” inch away from the corner. I’m sending it back.
    I found and ordered on Amazon a DGTECH C11P1510 battery that also states it’s a compatible battery for the Asus ZenPad S 8.0 Z580C Z580CA Z380C Z380C and looks exactly the same as the C11Pn9H but it costs more. $39.99 compared to the Cameron Sino for $23.89. Ouch! almost double the price. Also 1 Year Replacement Warranty as the Cameron Sino battery.
    Gary L. Turner - crwdns2934203:0crwdne2934203:0
  5. ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  6. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers gently pull off the tape over the ribbon cable
  7. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  8. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers gently remove the connector from the yellow slot
  9. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
crwdns2935229:05crwdne2935229:0
John Astfanous
crwdns2935283:010/04/16crwdne2935283:0
987 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S2G2
Thanks for helping me fix my beloved Zenpad!
Karen Detter - crwdns2934203:0crwdne2934203:0
Karen, where did you get the replacement daughter board? I can’t find one anywhere! - Christine
Christine Collister -
Bought it here:
https://www.asusparts.eu/en/Asus-90NP01M...
This is Part Number: 32YU1CB0000,
“ASUSparts” internal part number: 90NP01M0-R10010
4andrew - crwdns2934203:0crwdne2934203:0
Please clarify Step 9 - where exactly is the warranty tape that needs to be cut?
I have this unit and it stopped charging and stopped holding charge- I do not want to buy another unit as I invested a LOT of time in setting this one up…
Thanks
vshulyaker@gmail.com
Vladimir Shulyaker - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,878
