ASUS ZenPad S 8.0 Daughter Board Replacement
  1. ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  6. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers gently pull off the tape over the ribbon cable
  7. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  8. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the tweezers gently remove the connector from the yellow slot
  9. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS ZenPad S 8.0 Daughter Board Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
crwdns2935229:05crwdne2935229:0
John Astfanous
crwdns2935283:010/04/16crwdne2935283:0
987 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Cagle Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Cagle Fall 2016crwdne2935289:0
USFT-CAGLE-F16S2G2
Thanks for helping me fix my beloved Zenpad!
Karen Detter - crwdns2934203:0crwdne2934203:0
Karen, where did you get the replacement daughter board? I can’t find one anywhere! - Christine
Christine Collister -
Bought it here:
https://www.asusparts.eu/en/Asus-90NP01M...
This is Part Number: 32YU1CB0000,
“ASUSparts” internal part number: 90NP01M0-R10010
4andrew - crwdns2934203:0crwdne2934203:0
Please clarify Step 9 - where exactly is the warranty tape that needs to be cut?
I have this unit and it stopped charging and stopped holding charge- I do not want to buy another unit as I invested a LOT of time in setting this one up…
Thanks
vshulyaker@gmail.com
Vladimir Shulyaker - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,947
