This guide covers the basics of replacing the Solid State Drive (SSD) in the ASUS ZenBook UX302LA-BHI5T08 laptop. The SSD is an important part in terms of storage as it acts like a second functioning Hard Drive. The SSD deals with digitized information unlike the Hard Drive’s mechanical storage capacity.
Flip the laptop over so the model stickers face the ceiling.
Remove eleven 7mm Phillips #00 screws that secure the back cover.
Using a spudger, carefully remove the back cover.
Remove the six 3mm Phillips #00 screws holding the battery in place.
Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
Carefully lift the battery up and out of the laptop.
Remove the two 3mm Phillips screws from the solid state drive.
Grip the SSD and pull gently away from the connection port to remove it.
I’m curious… I just bought one of these, and after opening it up I only see 1 ram slot just like in your pictures. I can see I have 1 stick of 4gb installed, but task manager shows I’ve got 6gb installed soooo where’s the other RAM slot!? there’s another 2gb stick somewhere and I’d love to upgrade! Thanks!
