Whether you have low storage or if you just want to upgrade the storage on your Asus ZenBook Flip 15 Q528 laptop, this is a guide on how to replace the NVMe M.2 SSD drive.
A near-full SSD can significantly decrease performance and prompt "Device Full" errors. Make sure to check and delete any applications, images, or files taking unnecessary space before buying a new SSD. However, if those applications are essential programs, then upgrading the SSD is the move. Upgrading or replacing the SSD with a larger SSD can improve performance and provide more space for files.
Before getting started, be sure to backup your data from the SSD to a separate external drive before attempting. Additionally, remove all charger plugs, and of course power the laptop off.
Remove all eleven screws on bottom side of laptop:
One 7.5 mm Phillips #00
Ten 3.6 mm T5 Torx
Slide opening picks under the lower case to loosen the cover.
Move clockwise around the cover to loosen the cover evenly.
Remove the lower case.
Release the battery connector by pushing upwards on the silver colored lock.
Push inwards in a pinching motion on the battery cable and slightly pull upwards to disconnect the battery connector.
Remove the single 3 mm Phillips #00 screw securing the SSD.
Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
To reassemble, complete the steps in reverse order.
Hopefully, this guide was a useful resource to replace the NVMe M.2 SSD from a ASUS ZenBook Flip 15 Q528 computer within 6 quick and easy steps!
