This guide will demonstrate how to replace the front camera of a Zenfone 3. This may be necessary if the camera no longer displays a picture or displays a distorted picture. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, pull put the SIM card tray and set it to the side.
Remove the two 2 mm screws using a Torx T2 screwdriver.
Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
Peel the copper adhesive off.
