ASUS X552LAV-BBI5N08 Screen Replacement
  1. ASUS X552LAV-BBI5N08 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 12mm screws located at both the battery area and the bottom panel, with a Tri-wing Y1 screwdriver.
    • Slide the bottom panel down and lift it up to remove.
    • Remove the seven 5.5mm screws located at the bottom area with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to split keyboard from base of the laptop.
    • Make sure to start from one end and go around the edges.
    • Flip laptop to sit on its bottom.
    • Lift keyboard up by the front edge.
  5. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the small locking flap for the two ZIF connectors.
    • Unplug the connectors that are keeping the keyboard connected.
  6. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the locking flap for the ZIF connector.
    • Unplug the connector.
  7. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip laptop to sit with the screen on the bottom.
    • Use tweezers to remove the square decorative sticker from the top of screws from the edge of the screen frame.
    • Remove six 4mm screws (with a JIS #1 screwdriver) from under the stickers and both of the hinges.
  8. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release hinges with the motion of opening a book.
  9. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry apart the frame from the edge of the screen
    • Go around the edges til the frame pops off from the screen
  10. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove eight 4mm screws from the corners of the screen using a JIS #000 screwdriver.
    • Flip the screen towards the bottom panel face down.
  11. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the tape from the top of yellow lock.
    • Open the yellow ZIF connector.
  12. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape completely from the back panel.
  13. ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the casing from the edges of the screen by removing the eight 2mm screws with a JIS #000 screwdriver.
    • Pull the screen up to remove it.
Jason Vo
crwdns2935283:002/15/18crwdne2935283:0
881 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S17-G1, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S17-G1, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S17G1
crwdns2942667:0crwdne2942667:0 493
