ASUS X552LAV-BBI5N08 Fan Replacement
    1. ASUS X552LAV-BBI5N08 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Battery is not showed in pictures.
      • Flip the laptop face down.
    2. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the right button to the left.
      • Hold the left button to the right.
      • While you hold the left button in position, slide the battery out by pushing it away from you.
    1. ASUS X552LAV-BBI5N08 Fan Replacement, Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the bottom panel. It is at the opposite end of the battery.
      • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
    2. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove bottom panel by lifting it up.
    3. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
      • Slide the hard drive out to the left.
    4. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use opening tool to split keyboard from base of the laptop.
      • Make sure to start from one end and go around the edges.
      • Use Tri-wing Y1 screwdriver to remove two 12mm screws from battery area.
    5. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip laptop to sit on its bottom.
      • Lift keyboard up by the front edge
    6. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip up the small locking flap for the two ZIF connectors.
      • Unplug connectors that are keeping keyboard connected
    7. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip up the locking flap for the ZIF connector.
      • Unplug the connector that is keeping the keyboard connected.
    8. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove keyboard from laptop.
      • Remove the five 4mm screws (with a Tri-wing Y1 screwdriver) that are both connecting the fan and motherboard.
      • Pull out WiFi from below the cooling fan by lifting the edge nearest to the fan and sliding it towards the fan.
    9. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift yellow ZIF connector from the top of the motherboard to remove the connector.
      • Lift up motherboard from bottom edge towards the screen.
    10. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the two bundled cable connector from pin sockets below the fan.
      • Remove the motherboard and place on a flat surface.
      • Remove four 4mm screws with a Tri-wing Y1 screwdriver from the CPU.
    11. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect bundled cable connector from the motherboard
      • Remove fan part from the motherboard.
    12. ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X552LAV-BBI5N08 Fan Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the black tape from the top of the fan radiator.
      • Remove radiator by tilting it down and pulling it out from the fan.
Jason Vo
crwdns2935283:002/15/18crwdne2935283:0
891 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S17-G1, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S17-G1, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S17G1
crwdns2942667:0crwdne2942667:0 900
