ASUS X550LB-DS71 Fan Replacement
  1. ASUS X550LB-DS71 Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  6. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  7. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard to show the underside.
    • Locate the square fan connection attached to the motherboard.
    • Disconnect it using the tweezers (blunt).
  8. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black tape from the fan as seen in the marked location.
    • At this point, the fan is now disconnected from the motherboard.
Nathan Dyer
crwdns2935283:009/25/17crwdne2935283:0
550 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S16-G1, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S16-G1, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S16G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,138
