ASUS X550LB-DS71 Fan Replacement
crwdns2869540:0crwdne2869540:0: 2 k
5
27
146
1 978
crwdns2955950:0crwdne2955950:0: 1
crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 35 - 40 crwdns2931279:0crwdne2931279:0
The fan helps get rid of the excess heat in the laptop. A damaged fan can cause overheating and poor performance. This guide explains how to replace it.
    1. ASUS X550LB-DS71 Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure to switch off your laptop before starting.
      • Place the laptop on a flat surface with the bottom side facing upwards.
      • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
      • Using both hands, slide the back panel away from the laptop horizontally.
    2. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
      • At this point, it is advised to disconnect the hard drive from the motherboard.
    3. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the plastic opening tool, open the back cover of the laptop.
      • It is recommended that you start from a corner and run the tool along the edge of the cover.
      • Be careful not to bend or crack the cover.
    4. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the three ribbon connectors.
      • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
      • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
    5. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
    6. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
      • Disconnect the optical drive from the motherboard by sliding it to the right.
    7. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS X550LB-DS71 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the motherboard to show the underside.
      • Locate the square fan connection attached to the motherboard.
      • Disconnect it using the tweezers (blunt).
    8. ASUS X550LB-DS71 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the black tape from the fan as seen in the marked location.
      • At this point, the fan is now disconnected from the motherboard.
Nathan Dyer
crwdns2935283:009/25/17crwdne2935283:0
550 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S16-G1, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S16-G1, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S16G1
my mouse of laptop not working pls guide to repaire
Parneet Bhatti (Mantri) - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 146
crwdns2959996:0crwdne2959996:0 1,978
