ASUS X502CA Screen Replacement
  1. ASUS X502CA Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X502CA Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove plastic square covers on both bottom corners exposing the screws below using tweezers.
    • Remove the screws under the plastic square covers, using a Phillips #00 screwdriver.
    • Screws are black, 50mm in lenght with a 20mm diameter.
  2. ASUS X502CA Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X502CA Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the trim from the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
  3. ASUS X502CA Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X502CA Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four phillips screws (two on top and two on bottom) using the Phillips #00 screwdriver.
    • The screws are black, 45mm long and 15mm in diameter with a philips head
  4. ASUS X502CA Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X502CA Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop the screen out from the top and lay flat on the keyboard.
    • Do not pull screen away from keyboard, as it is still attached by a wire at the bottom.
  5. ASUS X502CA Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X502CA Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the clear tape that is securing the video cable connector using your fingers or tweezers.
  6. ASUS X502CA Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS X502CA Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the screen using tweezers.
  7. ASUS X502CA Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the damage screen with a new one.
    • Replacing the bezel trim requires the bottom to be inside the ends of the hinge cover. Be careful not to break the bezel when doing this.
    • Removing the hinge cover has a chance of breaking the tabs that hold it on. Remove it carefully.
Anthony Taylor
crwdns2935283:001/28/15crwdne2935283:0
354 crwdns2915208:0crwdne2915208:0
Clemson, Team 14-1, Shirley Winter 2015 crwdns2935289:0Clemson, Team 14-1, Shirley Winter 2015crwdne2935289:0
CLEM-SHIRLEY-W15S14G1
crwdns2942667:0crwdne2942667:0 3,529
