The screen is one of the most important parts of a laptop, as you won't be able to see anything you're doing without it, which is kind of the point. The disassembly isn't too complicated, there's just a lot of screws that need to be removed.
crwdns2935267:0crwdne2935267:0Metal Spudger$2.99
Using a Spudger, gently pry up the keyboard.
crwdns2935267:0crwdne2935267:0Nylon Tipped Tweezers$4.99
Rotate the keyboard to face downward.
Pull out the blue wiring connection. Use tweezers to make it easier to remove.
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Slide the disk drive out of the device.
On both the front and back panel, remove every screw you see.
Use the spudger to pry up the front panel from the back panel.
Using the Philips screwdriver, unscrew the screws shown in the pictures.
Unplug the wire connecting the screen to the motherboard.
Take the screen off by pulling it straight up off the bottom.
