ASUS VivoBook S400C Trackpad Replacement
  1. ASUS VivoBook S400C Trackpad Replacement, Remove the Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Trackpad Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Trackpad Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull left and lift out the hard drive.
  8. ASUS VivoBook S400C Trackpad Replacement, Heat Shield: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Heat Shield: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  9. ASUS VivoBook S400C Trackpad Replacement, Display Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black tape securing the keyboard ribbon cable to the display connector.
    • Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
  10. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the clear tape from the motherboard display connector.
  11. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position spudgers on the white tabs on either side of the connector and push evenly to unplug the display.
  12. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the three pieces of black tape securing the display cable to the motherboard.
    • Deroute the cable from the channel it sits in.
    • Move the cable to the side, out of the way.
  13. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to release the cables from the wifi card.
  14. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tapes securing the wires to the motherboard.
    • Move the wires to the side out of the way.
  15. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Hinges: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Hinges: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws securing the hinge on the left.
    • Pry the hinge up by hand to a 90 degree angle.
  16. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws securing the hinge on the right.
  17. ASUS VivoBook S400C Trackpad Replacement, Remove the Display: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Remove the Display: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Remove the Display: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the base of the laptop from the front.
    • Raise it to a 90 degree angle.
    • Slide it forward slightly to clear the hinges.
    • The display is now free.
  18. ASUS VivoBook S400C Trackpad Replacement, SSD Card: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, SSD Card: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, SSD Card: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the I/O Board ribbon cable from the motherboard.
    • Flip up the retaining latch with a spudger.
  19. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the ribbon cable by the blue tab and pull it straight out from the connector.
  20. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the I/O Board ribbon cable from the I/O board.
    • Flip up the latch with a spudger.
  21. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon cable to expose the SSD device.
  22. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If present, remove any insulating sheet covering the SSD.
    • Remove the single retaining screw.
  23. ASUS VivoBook S400C Trackpad Replacement, Unplug the SSD from the motherboard: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Unplug the SSD from the motherboard: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the SSD by the sides and slide it out of the connector.
  24. ASUS VivoBook S400C Trackpad Replacement, Fan / Heatsink Assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The fan and heat sink do not need to be removed for this procedure.
    • Remove the screw securing the fan to the palm rest. All other fan and heatsink screws can remain in place.
  25. ASUS VivoBook S400C Trackpad Replacement, Motherboard: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Motherboard: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Motherboard: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the black cable connecting the motherboard to the speakers.
  26. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Trackpad: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Trackpad: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Trackpad: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the trackpad ribbon cable retainer with a spudger.
  27. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cable straight out from the connector.
    • Peel the trackpad cable off the conductive tape strip below it.
  28. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the first of the two conductive tapes grounding the trackpad.
  29. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the second conductive tape grounding the trackpad.
  30. ASUS VivoBook S400C Trackpad Replacement, Disconnect the LED Board Cable: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the LED Board Cable: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the LED Board Cable: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip up the LED board cable retainer.
  31. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ribbon cable straight out from the connector.
  32. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Keyboard: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Keyboard: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Keyboard: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a spudger on the ears on either side of the keyboard ribbon cable connector and push evenly on both sides to release it.
    • The retainer will only move a very short distance then stop.
    • Lift it slightly to relieve the tension.
  33. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the keyboard ribbon cable.
  34. ASUS VivoBook S400C Trackpad Replacement, Remove the Mounting Screws: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two mounting screws.
    • There are triangular arrows printed on the board pointing to each of them.
  35. ASUS VivoBook S400C Trackpad Replacement, Remove the Motherboard: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Remove the Motherboard: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and slide the motherboard toward the hard drive to clear the connectors on the opposite side from the case.
  36. ASUS VivoBook S400C Trackpad Replacement, Trackpad: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Trackpad: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Trackpad: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the retaining latch on the trackpad ribbon cable connector up with a spudger.
  37. ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the blue tab with fine tip tweezers and pull the cable straight out from the connector.
    • Gently peel the trackpad ribbon cable off the trackpad.
  38. ASUS VivoBook S400C Trackpad Replacement, Remove the Trackpad: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VivoBook S400C Trackpad Replacement, Remove the Trackpad: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the side of the trackpad farthest from the side of the case and slide it away from the edge to remove it.
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
75,637 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 324
