crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Place the laptop upside down so that the bottom panel is facing upwards.
Unscrew the following 10 screws
Eight 5 mm Phillips head screws
Two 10 mm Phillips head screws
Carefully peel the panel off of the bottom of the laptop.
Remove the following 6 screws:
Two 5 mm screws holding the fan down.
Four 3 mm screws holding the heat sink down
Carefully disconnect the only sliding connector by using a plastic opening tool to pry the connector out.
Remove the fan and heat sink by lifting it upwards.
Remove the tape holding the fan and heat sink together.
