crwdns2937539:0crwdnd2937539:0crwdne2937539:0
A fan is included within a computer to help ensure it will not overheat. If the fan within your ASUS Vivobook S300CA-BB15T01 isn't working, please follow the steps below to replace it.
Place the laptop upside down so that the bottom panel is facing upwards.
Unscrew the following 10 screws
Eight 5 mm Phillips head screws
Two 10 mm Phillips head screws
Carefully peel the panel off of the bottom of the laptop.
Remove the following 6 screws:
Two 5 mm screws holding the fan down.
Four 3 mm screws holding the heat sink down
Carefully disconnect the only sliding connector by using a plastic opening tool to pry the connector out.
Remove the fan and heat sink by lifting it upwards.
Remove the tape holding the fan and heat sink together.
