ASUS VG248 Disassembly
    1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly, ASUS VG248 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before you begin, lay the monitor face down on a smooth, clean surface.
      • Four rubbery covers hide four screws in the rear of the monitor.
      • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
    2. ASUS VG248 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
    3. ASUS VG248 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the stand from the display.
    4. ASUS VG248 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
      • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
      • Lay the cloth over one of the long edges of the display.
      • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
      • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
    5. ASUS VG248 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Repeat the procedure around the display, lifting up the center of the next side.
    6. ASUS VG248 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Move around to the other long side and lift up on the center of the bezel.
    7. ASUS VG248 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the center of the final side and lift the bezel away from the rear case.
    8. ASUS VG248 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now that you've freed the centers of the four sides, it's time to move on to the corners.
      • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
      • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
    9. ASUS VG248 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Jimmy
      $7.95
      • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
      • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
    10. ASUS VG248 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
      • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
    11. ASUS VG248 Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the bezel.
    12. ASUS VG248 Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS VG248 Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the LCD out of the rear case.
      • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
    13. ASUS VG248 Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
crwdns2935229:024crwdne2935229:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
478,415 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2935297:072,401crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Do you know of any place that sell the replacement lcd screen?
treymcbrd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 166
crwdns2936753:030crwdne2936753:0 720
crwdns2942667:0crwdne2942667:0 138,911
