This is how you remove the keyboard on an Asus UX50V-RX05 Laptop.
Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
Remove the cable after pushing out the two black clips.
Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
Remove the cable after pushing out both black clips.
Remove the keyboard.
