ASUS UX50V-RX05 Hard Drive Replacement
    1. ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure the device is powered off and the battery is removed before beginning.
      • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    2. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
      • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
      • Remove the cable after pushing out the two black clips.
    3. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
      • Remove the cable after pushing out both black clips.
      • Remove the keyboard.
    1. ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the thirteen 5 mm J0 screws from the back of the laptop.
      • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    2. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    3. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
      • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    4. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift and remove the plastic cover to avoid damaging anything.
    1. ASUS UX50V-RX05 Hard Drive Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the screwdriver with the JO bit, remove the two Phillips 4 mm head size 5 mm long screws from the Hard Drive.
    2. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the Hard Drive over without lifting.
      • Using your fingers, unplug the cord by pulling it away from the hard drive.
    3. ASUS UX50V-RX05 Hard Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four black screws from the Hard Drive and slide it out.
James
crwdns2935283:002/14/17crwdne2935283:0
663 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 20-2, Remmell Spring 2017 crwdns2935289:0USF Tampa, Team 20-2, Remmell Spring 2017crwdne2935289:0
USFT-REMMELL-S17S20G2
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,125
